98 Blazer crank no start
Old Oct 25, 2022 | 10:50 PM
demming7's Avatar
demming7 is on a distinguished road
Default 98 Blazer crank no start
Recently picked up a 98 blazer 4 door, sat for a couple years, but ran good when parked.As of now cranks and will run by putting gas or starting fluid in intake, otherwise will not start, just spits and sputters. Just replaced fuel pump and filter. Do not have a fuel pressure gauge but manually pressed port valve down and shot gas out. Replaced Cap, rotor, wires, coil, and plugs still nothing. Has spark but almost seems an orange-ish color? have verified timing and that is good, and no codes present (cheap scanner). Anyone have any ideas or anything to check? Going to get a fuel pressure gauge soon, just looking for advice and if i’m missing something else first. Injectors? Thanks
Old Oct 29, 2022 | 11:26 AM
GeorgeLG's Avatar
You need to verify fuel pressure at the schrader fitting and especially leak down. Sometimes when vehicles sit the fuel changes to varnish and the fuel injectors get gummed up. Have you removed all of the old gas from the tank and refilled? I have had a couple of vehicles spit and sputter after a long storage rest. I pump out the fuel, put in new fuel, they start and run rough at first and then straighten out by the end of the new tank of gas.
George
Old Oct 29, 2022 | 05:14 PM
demming7's Avatar
Ending up being fuel injector, thanks !
Old Oct 29, 2022 | 07:20 PM
GeorgeLG's Avatar
Glad your fixed up.
George
kmenc67
14
Feb 19, 2021 02:09 AM
kuyatimmy
Apr 20, 2015 05:41 PM
Ruckusnuts
Jan 2, 2012 07:17 PM
drewdalegend
Sep 5, 2009 09:31 PM
havrelm1
Nov 20, 2007 04:15 PM
