99 Blazer death wobble with
Old Nov 27, 2021 | 01:34 PM
cptmiker's Avatar
cptmiker is on a distinguished road
Default 99 Blazer death wobble with
Hello All I have a 99 blazer with a straight axle convection
Dana 30 on Leaf springs about a 6 + lift I cant seem to correct the Death wobble at at 30 to 40mph its starts about 25 and just get worse and recomendation of what else to look at or help correct this would be great I will post pics as soon as i have taken them.
Old Nov 27, 2021 | 05:18 PM
Death wobble usually starts with something like a tire imbalance or irregular tread wear, then quickly gets violent because of loose suspension components. Have you tried rotating the tires front to rear? Are you running a track bar (Panhard bar)? Any play in the ball joints? How much caster does it have?
I would have somebody rock the steering wheel back and forth while you lie on the ground and watch the tie rod ends, ball joints, etc. for play.
Old Nov 27, 2021 | 09:19 PM
cptmiker's Avatar
I will check all the above. No track bar as this is a leaf spring install.
Old Nov 27, 2021 | 09:23 PM
Some leaf spring setups have a track bar. My Blazer doesn't, but my Ford pickup does, and I've seen some Dodge trucks that do. In most cases, I don't think it's necessary, but if you have a lot of spring arch or bad leaf spring bushings, you can have problems with the axle moving side to side.
Old Sep 16, 2024 | 07:56 PM
03BlazinRedBlazer's Avatar
03BlazinRedBlazer is on a distinguished road
*accidently posted reply in wrong thread. Sorry.
Last edited by 03BlazinRedBlazer; Sep 16, 2024 at 08:50 PM. Reason: Posted in wrong thread. Some how jumped over to a different thread I clicked reply to.
TonyZR2
Sep 3, 2021 05:13 PM
Chevy#
Jul 20, 2015 10:44 AM
TZFBird
Mar 7, 2015 06:13 PM
billbobagns
Nov 16, 2011 03:57 PM
Type RF
Jan 23, 2011 03:11 PM
