ABS delete in a 1997?
Old Apr 24, 2017 | 07:46 AM
marcblouin's Avatar
marcblouin is on a distinguished road
Default ABS delete in a 1997?
whenever my abs light is on my brakes works good, whenever my abs light goes off theyre horrible. I tried to find the fuse box under the hood to pull the fuse out but my abs module is exactly where the fuse box is supposed to be? cant find it. how can I delete my abs without pulling the fuse out? can I just pull out the sensor on each wheels?
thanks
Old Apr 24, 2017 | 12:50 PM
abig84's Avatar
you can probably just unplug a sensor or two if you cant find the fuse for it. just follow the wire up from a front wheel bearing and unplug one, should make your abs light come on disabling the abs
Old Oct 18, 2018 | 11:07 AM
fearday's Avatar
fearday is on a distinguished road
the fuse is located at the dashboard when you open driver door number 1 fuse 2nd row yellow fuse
you can also remove the wiring from abs unit , the front one to the left and keep your fuse in for drivepilot to work
Blackjackreno
Sep 11, 2019 06:34 PM
sdjames
Aug 24, 2011 03:13 PM
Bradley2424
Nov 1, 2010 09:14 AM
4pt9fiero
Jan 10, 2010 01:50 PM
stormshadow1
Apr 23, 2009 09:46 AM
