Air bag forever light solved
Old Jan 28, 2021 | 12:29 AM
Monkeywrench71986's Avatar
Monkeywrench71986 is on a distinguished road
Default Air bag forever light solved
So bought wife's 03 and had an airbag light that will never go out while on anyway. Drive through a puddle of substance and the bag light would go out....... For about 30 mins. Got the see service manual code never an actual code for say no communication or impact sensors ect. Connectors were clean and dry, bought a circuit safe tester of computer and airbag systems w digital gauge from dorman at twatozone for 26.00 after tax so did normal testing and reverse (ground testing) the ground wire was broken inside yellow wire armor water would get inside sheathing and would temporarily complete circuit. Some flux and really good soldering iron and some shrink wrap and i was in business. Hope this helps someone else w this annoying light. Oh passenger side was the location just above sway bar.
Old Jan 28, 2021 | 12:49 AM
Glad it was an easy fix! And thanks for the report!!
Old Jan 28, 2021 | 07:46 PM
rexmburns's Avatar
Super Moderator
Nice! In my VW the light wouldn’t go out and I don’t care about it enough to chase down what is likely a bad ground so I took the gauge cluster apart and cut a piece of rubber that I had laying around and put it in the hole and wouldn’t you know my light went out!!
Old Jan 28, 2021 | 09:19 PM
more than one way to skin a cat, 😂 I hadn't thought of that but hey if it works and the end result is good then its a winner.
Old Jan 28, 2021 | 11:26 PM
Good to know! Mine's been bothering me for a while now with the light randomly on and off. I will need to take a look at that, thank you!
Old Feb 17, 2021 | 02:07 PM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
My car also have exactly same issue and it always airbag light on never turned off
Old Feb 17, 2021 | 02:59 PM
When my clockspring broke, I "fixed" my airbag light with a 2.2 ohm resistor.
swanman35
Jan 22, 2013 07:14 AM
97CountryJukeboxLt
Dec 16, 2010 10:21 PM
hunter01
Oct 30, 2010 07:41 AM
Jones98
Dec 23, 2009 01:38 PM
hotrod28
Nov 4, 2006 08:11 PM
