Any One have an idea?
So im getting to wire my off road lights i have a 02 blazer zr2 and i cant find a hole any were to put the wires through the fire wall. and the fire walls plastic so its not like i can just push through it if any body has any idea how i can get the wires through the firewall let me know thank you
yeah i know that but i got a 95 preude its just carpet fiber or what ever it is but when i ran the sub wires in that its like a carpet in the engine comparment its plastic in my blazer
I'm not sure what you are talking about? There are areas with heat shielding mats but there should be plenty of open real estate behind the pedals if you pull the carpet back. Just make sure you check the other side before you drill.
Ps: please use punctuation it makes it much easier to read and understand for others
I must say, that is the first hearing someone think the firewall is plastic (i would sell the jimmy if that was the case)
but what rex said, lots of space behind the firewall. Just be careful when drilling through, find an area inside, and locate that area on the firewall to make sure no wires ect are in the way
I know the firewalls not plastic but whats in front of the firewall in the engine compartment is plastic. But i found that i can just run the wires with the antenna wire, so i don't have to drill through the firewall
99Legendary
Jun 30, 2015 08:48 AM
grovercan
Oct 14, 2007 09:06 PM
