Any One have an idea?
Old Feb 6, 2014 | 03:30 PM
coeltonbozz's Avatar
coeltonbozz is on a distinguished road
Default Any One have an idea?
So im getting to wire my off road lights i have a 02 blazer zr2 and i cant find a hole any were to put the wires through the fire wall. and the fire walls plastic so its not like i can just push through it if any body has any idea how i can get the wires through the firewall let me know thank you
Old Feb 6, 2014 | 03:49 PM
rexmburns's Avatar
Super Moderator
Um your firewall is steel to start lol!! I would just drill a hole where you need it and use a rubber grommet to protect the wires.
Old Feb 6, 2014 | 03:56 PM
yeah i know that but i got a 95 preude its just carpet fiber or what ever it is but when i ran the sub wires in that its like a carpet in the engine comparment its plastic in my blazer
Old Feb 6, 2014 | 04:42 PM
rexmburns's Avatar
Super Moderator
I'm not sure what you are talking about? There are areas with heat shielding mats but there should be plenty of open real estate behind the pedals if you pull the carpet back. Just make sure you check the other side before you drill.
Ps: please use punctuation it makes it much easier to read and understand for others
Old Feb 6, 2014 | 05:02 PM
Lmao, alright ill check it out to see what I'm working with. I haven't looked at it from that way iv'e just been looking at it through the engine compartment.
Old Feb 6, 2014 | 05:03 PM
rexmburns's Avatar
Super Moderator
Yeah pull back the carpet from under the pedals and you will be good to go!!
Old Feb 6, 2014 | 05:53 PM
richphotos's Avatar
I must say, that is the first hearing someone think the firewall is plastic (i would sell the jimmy if that was the case)
but what rex said, lots of space behind the firewall. Just be careful when drilling through, find an area inside, and locate that area on the firewall to make sure no wires ect are in the way
Old Feb 6, 2014 | 06:05 PM
I know the firewalls not plastic but whats in front of the firewall in the engine compartment is plastic. But i found that i can just run the wires with the antenna wire, so i don't have to drill through the firewall
99Legendary
Jun 30, 2015 08:48 AM
97Beater4WD
Mar 24, 2012 03:46 PM
johnwiseman
Lifting Tech
Nov 3, 2008 09:51 PM
grovercan
Oct 14, 2007 09:06 PM
mojoman13
Engine & Internal
Sep 21, 2006 10:51 PM
