any one wanna help me?
Old Mar 15, 2012 | 09:31 PM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
Default any one wanna help me?
hey yall, is there any one near me that would like to help me with my truck? i just need some help figuring out exactly whats wrong with it. im pretty sure it has something to do with the CV axils but i just want someone that knows about blazers that could help me. im in thomasville
Old Mar 15, 2012 | 09:41 PM
Rottidog's Avatar
Try posting what it's doing or not doing. Sounds, vibrations, details about what's going on, what you've done to figure it out etc.
That way you may be able to fix it or at least diagnose it & have ideas about what has to be done to correct the issue. Research on here on that particular issue would probably lead you to fix it.
Old Mar 15, 2012 | 09:44 PM
ok when i turn and back up i hear a clunk and some times going in drive as well. so i crawled under my truck and i can wiggle the CV axil. and the part that goes into the diff is what wiggles the most.
Old Mar 15, 2012 | 10:26 PM
tibby's Avatar
Default .
Your not too far away from me. I go to 109-u-pull-it over in Thomasville some, but they are a bit pricey.
So when your in the middle of a turn, you hear it clunk? That does sound like it is the cv joint. Does it clunk when turning right but not left? Vice versa? Or does it clunk when turning either way?
Old Mar 15, 2012 | 10:27 PM
Rottidog's Avatar
OK, I'd say lift up the front end & wriggle the tire. If the tire moves more than the axle shaft, then it's the CV joint that's bad. Try holding the axle shaft still & have someone move the tire to isolate the issue. Again same conclusion but if the CV joint is ok (doesn't move) then the axle is the issue or something in the front differential.
Does it make more noise at full turn, forward or back? If it does I'd say CV joint. You're sure it's coming from the front & not a U joint by the trans or at the rear diff?
At least this gives you ideas or an idea as to WTF is going on lol. The more info you provide the more people will get an understanding & possibly help out.
Old Mar 15, 2012 | 11:35 PM
yes i am positive its from the front and i will try all that.
97Beater4WD
Mar 24, 2012 03:46 PM
xgiovannix12
The Chop Shop
Aug 9, 2011 05:43 PM
xgiovannix12
The Chop Shop
Jun 21, 2011 07:53 PM
xgiovannix12
May 16, 2011 08:51 PM
johnwiseman
Lifting Tech
Nov 3, 2008 09:51 PM
