anyone instaled HID head lights on a blazer
Old Mar 25, 2008 | 07:05 PM
  #121
drperry's Avatar
Default RE: anyone instaled HID head lights on a blazer
Did you get the wiring harness with it?
Old Mar 25, 2008 | 08:25 PM
  #122
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
i have them, pm me about them, i have 6000k and they are SO worth the 275 i payed, i will never go back to regular bulbs
just read my post i made a while abck here
https://blazerforum.com/m_120622/tm.htm
Old Mar 26, 2008 | 12:26 AM
  #123
zackbennett's Avatar
zackbennett is an unknown quantity at this point
Negative I didnt get the wiring harness with it, Im gonna try a new relay in my fuse box and if that doesnt work I'll have to order a harness..
Also does anyone have any idea why when i hook them up i have to turn on the highbeams for them to come on.. even though they are plugged into the lowbeams, cant seem to wrap my head around that one.
Old Mar 26, 2008 | 03:17 AM
  #124
drperry's Avatar
Did you double check and make sure they're plugged in properly?
I think the highbeam plug will fit into the low beam plug... Are your high beams on when you turn your headlights on?
Did you do the quad beam mod?
Old Mar 26, 2008 | 11:37 AM
  #125
ok, idk if tis what you asking, the brights lights during the day are on but are dimmed, tese are drls, at night a snesor on you dash board turns on yor regular lights for you, you want to hook up the HIDS to LOWBEAMS(becasue thats what gets used the most) the switch is configured that when you turn on our highs, it turns off your low beams and vice versa, and since hids take about 6 seconds to come on, i highly recomend them as low beams, i hope that helped i could be completly off
Old Apr 6, 2008 | 07:09 PM
  #126
Yeah upon further review, every single time I hook the HID's up they blow the fuse in the Relay center within about half a second of turning the lights on. I ordered a wiring harness and Im hoping that will take care of the problem..
Old Apr 6, 2008 | 07:32 PM
  #127
drperry's Avatar
Which kit did you get?
And the harness should ALWAYS be used with HID's... Factory electronics just aren't built for that initial start up charge.
Jake--Blazer
Jul 17, 2013 02:04 AM
NEW YORK BOY
Mar 31, 2011 09:10 PM
jjimmy
Nov 4, 2007 11:53 AM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
