best oil lines
Old May 7, 2014 | 07:56 PM
The direction of oil flow must remain the same with the new lines. At the oil filter adapter on the engine, one line goes to the remote filter adapter under the radiator, the other comes from the remote filter adapter and back to the engine. Mark both ends of both lines on the aluminum tube, (next to the crimp connections). Then install the new line. Or, just do one line at a time
Old May 7, 2014 | 08:10 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
one at a time sounds good haha, yea that wouldnt be good. ill hgaave to find that thread, it gave pictures so i can piece together all the info your telling me captain hahaha...sucks being a visual learner
Old May 8, 2014 | 08:42 AM
cleburne red's Avatar
When I did mine I drew a picture of how the lines went, to make sure they went back the same way. You could also try taking a picture.
Old May 8, 2014 | 10:50 AM
er0ck273's Avatar
id probably do both to be honest. now with that being said, which lines are better gasket wise? the napas are built it, and the dormans come in as extras.
Old May 8, 2014 | 02:15 PM
The Dorman lines come with the gaskets, or you can get them seperately. As long as you torque them correctly, they don't leak. If you over or under tighten them, chances are they'll leak.
Old May 8, 2014 | 03:20 PM
er0ck273's Avatar
what would be the proper torque on the lines? i feel like where they connect to the pan is leaking also, so id probably just get the gaskets also, cause i saw a few options where they were "extra"
Old May 8, 2014 | 08:28 PM
er0ck273's Avatar
http://www.justanswer.com/gm/1vqna-r...nes-motor.html
does this sounds about right for replacement of both lines?
Old May 9, 2014 | 08:51 PM
Yup, that's it.
Old May 16, 2014 | 12:56 AM
girlsslingerie's Avatar
girlsslingerie is on a distinguished road
yea i know the dorman's come with a lifetime guarantee. i bet they have millions in storage knowing people that know why they leak arent buying them. what do the modern ones, or i should say ones that don't leak look like haha
Old May 16, 2014 | 11:58 AM
richphotos's Avatar
The modern ones that dont leak are invisible, its quite amazing actually. Since I installed those invisible ones I have not had a leak since
(I actually just deleted it all and put the filter back on the block)
