best oil lines
The direction of oil flow must remain the same with the new lines. At the oil filter adapter on the engine, one line goes to the remote filter adapter under the radiator, the other comes from the remote filter adapter and back to the engine. Mark both ends of both lines on the aluminum tube, (next to the crimp connections). Then install the new line. Or, just do one line at a time
what would be the proper torque on the lines? i feel like where they connect to the pan is leaking also, so id probably just get the gaskets also, cause i saw a few options where they were "extra"
http://www.justanswer.com/gm/1vqna-r...nes-motor.html
does this sounds about right for replacement of both lines?
yea i know the dorman's come with a lifetime guarantee. i bet they have millions in storage knowing people that know why they leak arent buying them. what do the modern ones, or i should say ones that don't leak look like haha
The modern ones that dont leak are invisible, its quite amazing actually. Since I installed those invisible ones I have not had a leak since
(I actually just deleted it all and put the filter back on the block)
