Blazer question... will you help me out?
Special key is a lug nut key and they are after market. It prevents the common thief from stealling your wheels easiely.
Its extremely rare to find a key that will work other than the original, there is no Master Key.
Working in a tire shop for a couple of years we would get vehicles in where the owner lost the lug nut key. They are told it takes about 1hr labor and they pay for tools. By far the easiest way to remove all four locking lug nuts is to pound an impact socket onto the lug, then unbolt it. Your not getting the lug out of the socket and both have to be replaced, and the owner is paying for them both.
Now if that doesnt work, option two. Again owner is paying for tools.
Pull out the drill and drill bits. Start small and work your way up, your going to drill out the lug stud, this is hardened steel and it takes about 1hr per wheel. Once the mut is off, the wheel comes off, and the brakes come off, the old lug stud is driven out and a new one pounded back in.
Same thing happens if you cross thread your lug nuts, pray the guy in the garage has a heavy duty impact gun. I have broken the studs off with my impact gun, granted it was only on cars, trucks is option 2 above. Figure $60-$90 per labor hour. Just because there are 5-8 bolts holding your tires on doesnt mean its a no brainer. Ive seen all 5 studs break whiel the car was on the interstate. That tire does some serious damage to teh fender well when it comes free.
Any tire shop can get the lock nuts off and replace them with regular ones -- probably while you wait... probably fairly cheap. Then, if you still want locks, you can pick up a new set at any auto parts place. Remember, you only need one per wheel!
Snowmonsterdude
Headers, Intake, & Exhaust
07-12-2011 08:10 PM
streblo
01-28-2011 06:00 PM
mxboy96
01-11-2010 06:11 PM
