Blazer Rebuild
I decided to do an entire overhaul of my blazer due to how many oil leaks and problems its having. I'm gonna check the bearings and crank to see the wear on it, if its bad we are going to drop the brand new updated 4.3 in it. If the engine looks good we are going to go ahead and replace all the worn parts and build up the engine, also going to be doing a complete trans rebuild. This happens monday/tuesday, wish me luck :P Ill go ahead and post pictures with progress.
Depends on the gears that the Colorado has...
I bet'cha a 3.7 would smoke ya, lol... or, at least it should... it's got a boatload more HP and almost as much TQ with a lot less weight, lol.
Then again, the 4.3 is built pretty much for pure torque out of a V6, lol
Good luck with the rebuild. Sux ya gotta do it but hey, it happens.On the plusside though,if ya gotta start replacing stuff its a perfect time to do some performance and dress up stuff since you have the time and room.
Ok we got the engine out today and found all the leaks and some bad cooler lines. We are going to put a performance bearing kit in tomarrow. But I came into some extra money and want some more performance. Which of these addons would be most cost effective.
Headers
Intake Manifold
Cam & Lifters
Headers
Intake Manifold
Cam & Lifters
Sounds like your gonna have some fun there. I'm thinking about buying a junk 4.3 to start doing a complete tear down and rebuilt on with some extra goodies to eventually do a swap with, I've had some serious problems as of late and since it's my DD I can't have it sitting while doing a rebuild.
As far as what addons, I would go with the headers first, your cam and lifters will appreciate the extra breathing room a little more than the stock manifolds. If you can do both, that would be great, but I can understand if that is not feasable. From what I have read on here, the stock manifold is going to be your best bet on the 4.3, but I could be wrong.
gmoney30
Jan 22, 2010 07:07 PM
88s10Blazer
Dec 25, 2007 09:29 PM
