blazer specification help
Old 01-22-2009, 09:47 AM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
Default blazer specification help
(not sure if this is were i should post this.)
currently I am taking an automotive class up on college. (I just recently bought a Blazer. 2001 4dr, 4wd) Well we have this spec. sheet that we need to fill out but I cant figure out all the answeres because part of them come from the door jamb sticker which is non existant on my vehicle. I was hoping that some of you could help me fill out this sheet as you all have tons more experience than I with the blazer.
also if any of you know how to get new stickers or at least a sheet that describes some of the car that would be great. I already tried gm customer service and got two answeres that didn't work. thanks a load guys!!!!
On Vehicle Information:[/i][/b]
1. Year: 01 (Many people make a mistake about the year of their car. Do not look on the driver’s door for this. The best place to find this is on the under-hood emissions label).
2. Make: chevy
Model: blazer
3. Engine size: 4.3 liter
number of cylinders 6
4. Recommended oil: 5w-30
Capacity: 5 qts
7. Recommended tire size: (look at the tire plaguard) p205/7015 or p235/70r15
8. Recommended tire pressure: (found on plaquared, NOT the tire): 36
9. Vehicle build date : dont know????? (found on label near driver’s door/jamb dont have labels).
10. Transmission type (automatic, 4 spd, 5 spd): auto...
Model: dont know???
Information found on an electronic or hard copy source[/i][/b]
11. Recommended transmission fluid: dexronvi Capacity: 11qts
12. Recommended fuel & grade: unleaded 87
13. Spark plug gap: .060 Recommended spark plug: ac-delco Torque: 11
14. Initial ignition timing: ???? at ?????? RPM
15. Firing order: 1-6-5-4-3-2
17. Location of fuel filter: along the frame rail
Location of fuel pump:in the tank
18. Fuel pump pressure specification: ????????
19. Cooling system capacity: 11.9 qts Recommended coolant : gm goodwrench, dex-cool
20. For a 50/50 mixture of coolant/water, how much coolant is required? 5.95 qts
21. Recommended power steering fluid: gm-power steering capacity: ?quart?
22. Recommended brake fluid: delco supreme 11... dot 4
24. Brake rotor minimum thickness .965/.728 Rotor run-out specification .003/.004
24. Does this vehicle use a coolant recovery tank? yep
if so, where is it located? front passenger side
26. According to the recommended maintenance[/b] schedule, how often should you:
· Change your oil: 3000
· Change your timing belt (if equipped) : 30,000
· Change your drive /serpentine belt: 30,000
· Replace coolant : 150,000
· Change your spark plugs: 100,000
· Flush your transmission: 30,000
· Rotate your tires: 6,000
· Check your tire pressure: monthly
· Check your brakes: 7,500
if you know of better fluid or spark plugs or anything just let me know
Old 01-22-2009, 09:55 AM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
Default RE: blazer specification help
Go to the library and most of the answers are in a Chiltons or haynes manual. http://www.autozone.com/shopping/repairLanding.htm Click on specs. Also we can't help you unless you list what kind of blazer. There are also two ways to determine the year of your car(don't know which one you want). The model year or the year/month/place it was made in the door jamb. Goodluck
Old 01-22-2009, 10:07 AM
rriddle3's Avatar
Or go to GM Owner Center, register with your VIN, and you can download a .pdf of your owner's manual with the information in it.
Old 01-22-2009, 11:19 AM
sorry. it is a 4dr 2001 automatic 4x4..... it didnt come with the stickers in the door jamb at all
Old 01-22-2009, 11:29 AM
95Blzr's Avatar
Owners manual in the glovebox?
Old 01-22-2009, 11:36 AM
yeah. the big book? although it doesnt specify all of the things. like tire pressure. year etc. Its a generic book. Sadly the town i live in is reletively small and doesnt have books like that in the library. Thanks for the autozone link. so far its working great.. although i still would like to be able to find the serial # etc. year it was made month....
Old 01-22-2009, 01:12 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
serial number?
If you mean your VIN it is on the cash, drivers side (Bottom of the windshield from outside)
also on your registration.
Old 01-22-2009, 01:21 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
have you tried running down the RPO list from the sticker in your glovebox? it wont tell you everything from your list but will help with some not to mention you may learn some things you didnt already know about your vehicle (ie. mine came factory with keyless entry but no remotes when i bought it so i had no idea)
Old 01-22-2009, 01:49 PM
i havent run the rpo list yet. sorry no i know the vin number. I will update the sheet with what I have left to find. Autozone answered most of them. you can see if I put the right info in there or not.
Old 01-22-2009, 02:14 PM
riceh8r0512 is an unknown quantity at this point
Fuel pump is inside the gas tank.
Transmission model is 4L60E
Everything else you have looks to be correct from my knowledge. Can't help with any other other than what you had put in.
