Blazer Zr2 hit a tree. Trying to save!
Old Apr 3, 2022 | 05:25 PM
killhut1's Avatar
killhut1 is on a distinguished road
Default Blazer Zr2 hit a tree. Trying to save!
I was given a 2000 blazer zr2. The owner hit a tree with it. Front bumper was def bad. Going to replace the radiator support. The radiator is still good surprisingly. Luckily nothing touched the motor. Although the right side frame rail got bent in. the bumper mount is def bent back, but i plan on doing a fabricated bumper. Also plan on trying to bend the frame rail back as much as i can. Body lines were straight. No fender damage.
Do any of you have any thoughts on what I can/should do? Thanks in Advance!
This picture was taken before I removed the Radiator support.
Old Apr 3, 2022 | 09:57 PM
Looks like when my daughter rear ended someone with my wife's sonoma lol... I used straps and my blazer to pull the frame as straight as possible, then just beat the living life out of it.... I didn't have a torch, but that wouldve definitely helped!
Let us know how it goes!
This is what it looked like before i did the work
This is what she looked like afterwards
Old Apr 3, 2022 | 11:28 PM
As long as the rest of the frame is fine, I'd think this is very doable. Just a matter of tools, time, and gumption.
Old Apr 4, 2022 | 12:22 AM
Lol gumption... I've never heard that one before
Old Apr 4, 2022 | 08:34 AM
killhut1's Avatar
Oh wow. looks like it hit in the same area. Thank you for the response and photos!
Old Apr 4, 2022 | 08:21 PM
cage47's Avatar
cage47 is on a distinguished road
Here is mine. Sorry old low grade photo.
I bought it like this cheap. PO's kid ran right into the back of a big truck. Now my frame piece didn't sustain as much damage as yours but I did have to do a little tree chain yanks. If you do that be careful to use a chain hefty enough not to break or else you'll also have a broken windshield to replace (no I didn't do that but I'd seen it happen) Anyway. two weeks later and $1500 from the local junk lot and...
we drove her up to NY in feb three days after this. She lasted us from jan 2009 until sept 2013 when the engine finally siezed in Dallas. (RIP Little Easy) One thing I will point out is look carefully on how the frame might have affected the passenger door. I did pretty good with getting it all lined up but it did still have a small door seal leak I had to monkey with. (Ended up sliding a 1/2 inch fuel line in the door jam seal to get it to stop leaking.) It clicked over 200k on the trip up to NY. It lasted until 248k. So it can be done.
Old Apr 9, 2022 | 08:31 PM
killhut1's Avatar
UPDATE!!
Changed out the front clip bought some new engine parts. Motor now starts like a dream!! tightened my tie rod and and allignment isnt so bad. The frame was not bent beyond the suspension. Thankfully! Here is a picture with new front clip and and a picture where my frame bent in front of the suspension.
Bent frame in front of suspension
Old Apr 10, 2022 | 07:17 AM
Looking good! I remember when opened got rear-ended, they pulled the frame and body back and got it looking good again... and alot of time people are getting there frame straightened and body fixed
Old May 3, 2022 | 07:26 PM
killhut1's Avatar
Default Update on the Zr2 that hit a tree
Was able to get a new front end put on this thing! Motor is running! A couple windows, hood, and a lil body work and this will be hitting the trails!
Old May 4, 2022 | 03:59 AM
Good job! Can't tell it hit a tree... just looks like it ran into a pissed off ex gf lol
killhut1
May 6, 2022 07:16 PM
amazinnblazin
Apr 2, 2011 04:12 PM
jonnyisback
Oct 22, 2010 12:30 PM
1blkblazer422
Aug 28, 2008 10:02 PM
bmxbikes
Apr 14, 2008 06:07 PM
