Block bell housing sep.
Old Mar 20, 2008 | 11:50 AM
Default RE: Block bell housing sep.
Transmission controls/electronics are the same. The only thing that is different between a '96-'97 to a '98+ is that there are 4 O2 sensors. In mid-'02, the injection system changed from the SCFI to the MFI setup (which is backwards compatible). The EGR system also changed as well as a few other misc sensors. But everything engine wise from '96-'01 will be the same.
Old Mar 31, 2008 | 12:06 PM
SCOTTY's Avatar
SCOTTY is an unknown quantity at this point
OK:
Engine is in (not completely hooked up but in!!!) Does anyone know what to do with the knock sensor if the new motor (2001) has a different style sensor where the 1996 is different? Do I have to mount it somewhere? the 96 has a 1/4 pipe thread for the sensor and the 01 has a 5/16 threaded hole??? Had to swap oil pan,oil pickup screen, exhaust manifolds and a couple sensors, but all in all not bad.
Scott
Old Mar 31, 2008 | 12:51 PM
You could try to use the new sensor, but may need to get the wiring pigtail and diagram for the new sensor as well.
Old Apr 15, 2008 | 01:07 PM
SCOTTY's Avatar
ok. engine is out, new one in....runs beautiful!!! now how about some help to change heater core, from the inside or outside?
Old Apr 15, 2008 | 02:54 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
To change the heater you almost have to remove the whole dash in a 96 its apain in the butt
Mjseyler
Jan 5, 2010 12:44 PM
fondo
Nov 9, 2008 10:09 AM
tkm3393
Sep 26, 2008 01:38 PM
95Blazer4x4
Mar 7, 2008 07:54 PM
hitr0099
Dec 10, 2007 11:23 PM
