blower motor help
Old Nov 13, 2012 | 09:24 AM
randyj68's Avatar
randyj68 is on a distinguished road
Default blower motor help
I wouldn't have posted a new thread but not finding exact circumstances in other posts. I have a 94 Blazer,, 4.3, 4x4. Was riding up the road Friday, smelled an electrical smell, said please dont be me and it went away. Noticed my heat/AC fan wasn't working on any speed on heat or ac. Checked the fuse and its good, pulled the connector off the blower motor resistor and the test light comes on when testing each lead when changing speeds, put a new resistor in......no change, pulled the hot wire off the blower motor, test light comes on, took a new fan out to the truck, hooked upp a ground and plugged it in, it comes on, turns slowly and wont change speeds. Basically im confused on what to fix, is the the fan switch on the dash, blower motor or what. Any help appreciated! !!
Old Nov 13, 2012 | 09:31 AM
Toddinetowah's Avatar
Toddinetowah is on a distinguished road
Had to change fan switch in dash on mine.
Old Nov 13, 2012 | 10:27 AM
randyj68's Avatar
I have the slide switch, dont look that bad ti change, just can't afford to throw parts at it, luckily know a guy at the parts store and was able to eliminate the resistor and blower motor.....i think. I assume the switch fixed yours? Thanks again
Old Nov 14, 2012 | 06:31 AM
randyj68's Avatar
In testing the current at the resistor harness and at the blower motor do i need too check for how many volts or amps?
maxvamp
Oct 31, 2020 08:19 AM
geofflesehr
Sep 16, 2013 07:26 PM
fitztool
Dec 9, 2010 06:50 AM
jwalker89
Jul 10, 2010 02:26 AM
highlife756
Nov 16, 2009 03:57 PM
