Blue devil pros/cons??
Old Oct 28, 2021 | 02:18 PM
Bamabreeze's Avatar
Bamabreeze is on a distinguished road
Default Blue devil pros/cons??
Anyone ever use blue devil oil stop leak to fix oil from leaking/burning through exhaust and out tail pipe?? What's the do's and donts..thanks
Old Oct 28, 2021 | 06:29 PM
I wouldn't use any stop leak myself.... could do worst....
Old Nov 2, 2021 | 01:15 AM
Crazyeights's Avatar
Crazyeights is on a distinguished road
Forget it. Take the time and fix it right.
Old Nov 2, 2021 | 11:17 AM
GeorgeLG's Avatar
I never use any of these products, well not since a disasterous outcome in 1975 anyhow. I believe that these are seal conditioners, their basic job is to get rubber to swell. Not sure that helps bad rings, maybe it helps valve seals, might even make things worse if the product has any cleaning properties and it’s rings. I believe that high mileage oil uses the same principle and may be a safer choice using a top shelf brand. Agree that it’s better to fix it properly.
George
Old Nov 4, 2021 | 07:26 AM
Bamabreeze's Avatar
So I come to find out that hopefully my situation is more simple than thought..a local mechanic thinks either the diaphragm or one of the injectors is bad and the other injector is overloading the intake and burning through the exhaust which is the reason for the smoking/smelling of burning gas/oil smell... hopefully this resolves the issue..thank for everyone's time and advice..will update soon.. ✌️
Old Nov 7, 2021 | 11:49 AM
jimspahr@msn.com's Avatar
I hope you have a happy solution. Let us know what you find out. Plus what you did to solve it.
Old Nov 11, 2021 | 01:05 PM
Bamabreeze's Avatar
Ok with 🤞I think I have resolved the issue,after a complete rebuild kit in throttle body and a good cleaning with new injectors along with new plugs and fuel filter it seems to be running fine..the smoking from the exhaust has stopped and the oil level is good..A big thanks to all that has shared input on the situation
Old Nov 11, 2021 | 01:17 PM
GeorgeLG's Avatar
Glad you got it fixed
George
RedValor
Aug 21, 2021 09:07 AM
medicineman2011
Dec 26, 2017 01:56 PM
Autotech13
Aug 28, 2013 09:22 AM
d02046612
Jan 27, 2010 04:26 PM
mdemers2006
Aug 10, 2007 11:39 PM
