Bought my wife a Blazer today...
hey, how do you like those tires? i've been running the same tire since summer and they are amazing. i have alittle over 12,000miles and they hardly signs of wear. they grip almost everywhere and i can leave my truck in 2wd in most cases. even in snow, they will spin for a sec then just lanuch forward. only problem i have with them is that they seem to loose chunks from the tread to easy when rock crawling. its great watching my truck go place the big boys go and i'm only on 31s. i used to run with guys on 36's and up and i could follow them down most trails. i get lots of complements from ppl about my tires, most ppl have never seen a balzer/jimmy 4dr lifted with mt tires.
At Sway_89S10:
You should totally do it. The only drawback I have found with the upgrades (tires) is that at highway speeds it downshifts more often, but not enough to be an issue. Gas mileage didn't drop much either. If you wanted to Mod yours without any drawbacks 30x9.5's with a torsion bar crank to get the front off the ground shouldn't effect anything but the speedo.
got the same tires on mine i just had the speed-o recalobrated by the local speed/dyno shop for $25 and took off the speed limiter and adjusted the shift points. makes a hell of a difference. these tires scream mt's but ride like at's
and for $110 a piece thanks to grand mom's walmart discount card!can't beat em!
6Cyl'erThriller
Apr 4, 2011 07:06 AM
