brake lights only
Old Sep 23, 2010 | 05:29 PM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default brake lights only
i wish to hookup 4... 4 inch led lights on the rear of my blazer as brake lights (ONLY).
What wire color will do the trick.??????
Old Oct 8, 2010 | 07:05 PM
jack.sprat's Avatar
jack.sprat is on a distinguished road
The black ones yellow is park, brown is turn, black is brake.....
Old Oct 12, 2010 | 06:18 AM
R2P's Avatar
R2P
R2P is on a distinguished road
Make sure you don't overvolt the LEDs and be sure to use a resistor to limit the current. About the only thing that'll kill and LED is too much current.
Old Oct 12, 2010 | 06:37 AM
robertr728's Avatar
robertr728 is on a distinguished road
Black is the ground wire Yellow and Green are turn and Brown is park lights.The turn signal switch dishes out weather its flashing as for a turn signal or on steady as a stop lamp. You cant separate the two. If you have 3rd light or trailer wiring your can use those wires they are LT BLU. If not youll have to wire them to the turn signal wires. hope this diagram helps.
Old Oct 13, 2010 | 06:44 AM
on my old chevy, i put (4) 4 inch led lights on the rear deck and hooked 2 on each side of the brake light wires directly, no problem.
i also put (4) amber lights on the rear deck as signal lights and put 2 on each side of the brake light wires and hooked them directly into the brake light wires, no problems at all.
i am not an electronics wiz, so i dont know anything about this resistor installation.
Thanks..............................
tdbone1
Nov 9, 2014 07:54 AM
edavison
Dec 20, 2010 09:55 PM
step66
Oct 14, 2010 04:52 PM
SCBlazer96
Apr 16, 2010 08:39 PM
rryker
Apr 25, 2006 04:14 PM
