Bumper hex bolts size? - for 1997 Blazer 2-door 2WD
Old Mar 13, 2023 | 09:56 PM
97whiteblazer's Avatar
97whiteblazer is on a distinguished road
Question Bumper hex bolts size? - for 1997 Blazer 2-door 2WD
I'm installing a new bumper on my 1997 Chevy Blazer LS, 2-door, 2 wheel drive, 4.3 liter V6. While I'm at it, I'd like to replace the rusty bolts with brand new bolts, because I live in an area where metal rusts quickly.
When I measure the original rusty bumper hex bolts they seem about 2 millimeters shorter than 30mm - but perhaps bumper hex bolt measurements do not need to be extremely accurate?
(Apparently the "bumper" is also referred to as the "Impact Bar" - which helps to know when searching online). Several websites are showing that the bumper hex bolt size is: 1.25 x 30 mm
M8x1.25x30 Multi-Purpose Bolt - GM (11515758)
Here's 1 example:
https://www.gmpartscenter.net/oem-pa...-bolt-11515758
I'm considering purchasing these stainless steel HEX body bolts on Amazon since I live in an area where metal rusts easily.
M8-1.25x30 MM DIN 933 Metric Stainless A2 70 HEX Head Bolt/Screw,/933 (Quantity: 100) Size: M8-1.25 | Length: 30mm
Material: Stainless Steel
Grade Rating: Grade 8 8
Thread Size: m8-1.25
Exterior Finish: Unfinished
Manufacturer Grade: Grade 8 8
Quantity: 100
But before I order them, I hope to find out if this is the correct HEX bolt size for my 1997 Chevy Blazer LS 2-door 2-wheel drive truck?
Amazon Amazon
Thanks!
M8-1.25x30 MM DIN 933 Metric Stainless A2 70 HEX Head Bolt / Screw / 933 (Quantity: 100) Size: M8-1.25 | Length: 30mm - Stainless Steel.
I am also adding 3 photos of the existing rusty original HEX bolts from the front bumper:
Original (now rusty) HEX bolt from the front bumper of my 1997 Chevy Blazer LS 2-door, 2WD, 4.3 liter V6.
puttster
Aug 15, 2020 09:05 AM
rexazz2
Mar 2, 2013 08:57 PM
hypertek
Jul 21, 2011 10:19 AM
brucesblazer
Mar 31, 2011 11:30 AM
Duntov
Apr 3, 2008 10:40 PM
