Calling All Painted Frames
Old Jun 17, 2010 | 06:52 PM
Dbam31's Avatar
Dbam31 is on a distinguished road
need to do another layer on the frame and a gloss.
Old Jun 17, 2010 | 09:07 PM
DSMayo's Avatar
DSMayo is on a distinguished road
I need to do this when it gets sunny out. What is everyone using to paint the frame?
Old Jun 17, 2010 | 10:05 PM
84BlazerS10's Avatar
yeah, I was figuring I would have to clean up underneath and mask off part of the body.
What type of paint would be best and is there anything to watch out for?
How many cans of paint did it take to do the whole thing?
Old Jun 18, 2010 | 12:07 AM
97chevyblaze's Avatar
97chevyblaze is on a distinguished road
i had a quart of por 15 & i didnt even use the whole thing i used foam brushes too it came out very nice. just clean the frame with a wire brush then paint. make sure you use gloves if your going to do it cause this stuff doesnt come off easy. it cost like $31
Old Jun 18, 2010 | 01:14 AM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
I originally used engine enamel on the brake lines, fuel lines and the outside and lower part of the frame. Then I bought undercoating and rust converter from Walmart and I used rust converter on the crossmembers and anywhere it might be badly needed then I did the outside and lower part of the frame again. I can't do the inside because I can't get all the sludge off of it no matter what I do. The undercoating spray is junk and it keeps peeling off and leaving rust spots on the frame.
Old Jun 18, 2010 | 10:03 AM
try the por 15 & spray some brake cleaner on the stuff to see if you can clean it up a little better make sure you wipe it down good after tho. But for the dry spots thats where you use the wire brush. When i painted my frame i painted pretty much everything the back leafs the rear end, brake lines.. i just still need to do my a-arms but por 15 is very good and only needs one coat
Old Jun 18, 2010 | 11:28 PM
you can try some simple green to clean up so stuff too!
Old Jun 19, 2010 | 12:12 PM
rudd21's Avatar
rudd21 is on a distinguished road
Yes, POR 15 is a great product and will completely lock out rust if applied correctly. Be sure to topcoat the POR in any area that may be exposed to sunlight. POR 15 will not withstand UV rays. If not topcoated the finish will become chalky and eventually lose its rust blocking ability.
Old Jun 26, 2010 | 02:04 PM
old skool luvr's Avatar
i did the inner wheel wells as well as the frame rails.
that was all done with the paintable Rocker Guard (not that i'm gonna paint it anyways), it's not as messy as using undercoating.
the Rocker Guard also works well on other stuff too (not quite done with it all yet.......)
Old Jun 26, 2010 | 07:30 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
I love the painted frames, great looking
