Can a blazer pull a fullsize (k5)
Old Dec 5, 2010 | 11:09 AM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
Default Can a blazer pull a fullsize (k5)
i'm looking at getting a k5 blazer shell from the junkyard. no motor, tranny or transfer case. after it was loaded on the trailer the axles would be removed. i know a k5 with a motor, tranny, transfer case weighs a fuzz over 5,000 pounds. Do you think an s10 blazer could pull it? i trust the motor in it but the tranny is the part that worrys me. the 4l60e are no allision.
what do you guys think? i can borrow a 3/4 ton truck to pull it if i have to, but was wondering if the blazer would be up to it.
Old Dec 5, 2010 | 11:34 AM
NVANZEE's Avatar
You will be able to do it but the blazer will struggle doing it. If you have a truck available i would use that. One thing to watch for would be the tongue weight. If it is too much you will have some trouble steering. I had a 24ft boat behind mine and the steering was pretty loose. Also check the ratings on your hitch. With something that heavy you will want trailer brakes too.
Old Dec 5, 2010 | 11:35 AM
toaks1's Avatar
toaks1 is on a distinguished road
The 4l60e is the same transmission used on full size silverado and tahoe trucks. I believe the maximum factory rated towing capacity for a 4.3 s10 is around 5500lbs.
Old Dec 5, 2010 | 01:18 PM
oktain's Avatar
Tandem axle trailer? If yes that'll keep the tongue weight down and steering shouldn't be too much of an issue.
Power wise, the 4.3 "should" be able to do it, it has alot of torque, it's your driveline I'd be worried about, the 4L60E should be able to take it though.
Old Dec 5, 2010 | 03:31 PM
yeah its a tandem axle flat bed. i might be keeping the axles since i would have to remove them in 10 degree weather at the junkyard. i might just borrow the 3/4 ton. i would hate to blow something out on the DD
Old Dec 5, 2010 | 06:30 PM
UberFail's Avatar
UberFail is on a distinguished road
just save yourself the chance of destroying your DD and borrow the truck to make your life easier.
Old Dec 5, 2010 | 06:51 PM
oktain's Avatar
Just borrow the truck...
Old Dec 5, 2010 | 11:49 PM
chevytruckdood's Avatar
borrow the truck and come pick up my blazer for free ..........lol
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
Spartan66
Sep 29, 2008 11:57 AM
Jackal
Feb 15, 2007 07:18 PM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
