Canadians, L@@K! What freeze-plug is preferred for block heater install?
Old Dec 1, 2010 | 08:50 PM
69chevelle's Avatar
69chevelle is on a distinguished road
Originally Posted by swartlkk
All of the ones I have ever installed were held in with a bolt.
same here...
and Following the plug back to the block confirms the location.
Old Dec 1, 2010 | 09:26 PM
blazinloud's Avatar
also ALWAYS remember to unplug it before you drive away :P I busted mine that way and got shocked lol
Old Dec 2, 2010 | 12:41 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
As stated, it's the rear most freeze plug on the driver (left) side of the engine (basically the same location as the one above the starter, but on the opposite side of the engine). There are no freeze plugs located on the back of your block. The plugs that are back there do not open up to the coolant jackets, but rather blank off the bores for the cam & balance shaft.
There is a drain plug on both sides of the block.
There likely isn't any reason that it couldn't be put above the starter if it would fit and it probably would be easier than pulling the exhaust manifold which is what you will probably have to do (especially if 4wd).
I wasn't arguing I was making a statement saying you were right. notice the exclamation point not a question mark.
Old Dec 2, 2010 | 07:10 AM
I was clarifying for the OP. My response was not directed at you. One nice feature of our old forum software was the tag on posts that listed who you were replying to...
masterchf117
Aug 20, 2011 10:46 PM
iamchevyman5
Nov 10, 2010 05:07 PM
m00nwater
Oct 23, 2008 02:07 PM
nite_vison
Suspension Tech
Apr 12, 2008 03:28 PM
boulonman
Mar 5, 2007 05:10 AM
