Catalytic converters and a hello
Old Jun 20, 2013 | 10:47 PM
Brian_D's Avatar
Default Catalytic converters and a hello
Hey there is a been a little bit! good news, my catalytic converter has ate the big one! (the s10) not really good news at all tho. im going to order a direct fit and fix it my self tho, no way im paying 1000 to someone else to remove a few bolts and put a few bolts back on.
my one question is, which website do you think i should use? i was thinking rockauto, but i haven ordered car parts online so i was just looking for some sites that you have had good experiences with regard to price, speed of shipping, ect.
I have searched around on this topic but i really just wanted to say hi and i figured i would include the topic of my day.
thanks guys,
Old Jun 20, 2013 | 11:52 PM
richphotos's Avatar
I would use rock auto personally, if you search the site, you will find a discount code as well.
Old Jun 21, 2013 | 09:09 PM
Brian_D's Avatar
i found a place here that will weld on a universal for 300 out the door. not to bad i guess.
Old Jun 22, 2013 | 05:34 AM
Rumblur's Avatar
Rumblur is on a distinguished road
I think you can get a universal cat for around $90 at the local auto parts store. Buy it yourself and price installation... around here, it's $40.
Old Jun 22, 2013 | 06:49 AM
rexazz2's Avatar
I would stick with a direct fit convertor rather than be messing with the pipe
I just bought a set of front hubs from R.A with no problems
Just make sure to read all the details completely when making your selection
I would only buy a brand name convertor
Old Jun 23, 2013 | 07:11 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
if you want unbolt and replace Rockauto is the way to go. Or remove and cut the pipe so u can remove the guts then get a welding shop to weld it back up. FYI it will sound different.
Old Jun 24, 2013 | 12:22 AM
abig84's Avatar
those universal ones on the s10s are kinda trickey most of the ones ive done you have to cut off the old flange off of the old converter and weld it on the new one so you can use the factory hanger and so it will bolt to the pipe itself.
i kinda like that way better though then messing with the entire pipe off the manifolds you never know when or if those studs are going to break. so if you have a good welder id go with the universal.
Old Jun 24, 2013 | 09:31 PM
Brian_D's Avatar
i had it installed today, runs better so far and let me tell you that this thing just got so much LOUDER. i dont remember it being this loud, perhaps this universal cat has more flow than the stock ones? i dunno, but its crazy loud.
lets hope it solved my problems, time to move on to the senors that needs to be cleaned or replaced.
Old Jun 25, 2013 | 10:25 PM
abig84's Avatar
also if the old cat was clogged up it would have quieted down the sound. another thing ive noticed about these universals is they are garbage. they seem to last like 20-30k miles or 2-3 years. ive been at my job about 3 years now and about every week or so we are getting a cat coming back that i put in when i first started for the p0420 code, magnaflows, walkers, whatever only seems to last a few years.
Old Jun 26, 2013 | 10:24 AM
browntown's Avatar
browntown is on a distinguished road
$300 out the door is not bad.
I do a lot of side work, and I like to get cats at eCatalytic. They're helpful because that's their specialty.
The cat shouldn't make it louder. The muffler is downstream, and that should handle the noise.
As abig84 said, universals aren't OE quality. I wouldn't call them garbage, but 3 years and 30k miles is about what you should expect to get out of aftermarket parts. If for no other reason, the welds tend to rust out after that. They just don't make aftermarket exhaust or cats with premium steel. If they did, the cost would be much higher.
