Considering buying a 2002, what do I look for?
Old Jun 3, 2008 | 08:52 AM
fourtwenty's Avatar
fourtwenty is an unknown quantity at this point
Default Considering buying a 2002, what do I look for?
Hi,
I'm considering buying a 2002 GMC Jimmy 4x4 2-door (which is pretty much the same as a blazer, right?). It has around 96k miles. What kind of things should I be looking at? If maintained properly what kind of life can I expect to get out of it before I have any major problems?
Thanks!
Old Jun 3, 2008 | 09:07 AM
TripleBlackBlazer's Avatar
Default RE: Considering buying a 2002, what do I look for?
How much are they asking and where do you live?
EDIT: And yes, Jimmys Blazers and Bravadas are basically the same thing.
Have the ball joints checked out, check the remote oil lines, and check the rad/overflow for any gunk or sediment. Keep an eye on the gas gauge, if it fluctuates rapidly it may have a bad sending unit/fuel pump. Interior wise these truck are pretty tough-check to make sure all the windows (I'm assuming it's power) go up and down without strain and check your seat recline handles-they tend to snap off.
There is a thread named "Common quirks" or "Common problems" floating around here somewhere. That will give you a wider variety of answers from various owners. I have 86K on my '00 4x4 2dr Blazer and I had the ball joints replaced within the last year, oil lines leak some. No gunk in my rad/overflow but I think my heater core is clogged. I know the sending unit/fuel pump is muffed but I just fill up at 250 miles on the trip odometer and it's been fine since then. Both recline handles are snapped off but the seats are where I want them. If I need to change them I can use a flathead screwdriver and if I really needed to replace them it wouldn't be a hassle.
Old Jun 3, 2008 | 09:10 AM
fourtwenty's Avatar
ORIGINAL: TripleBlackBlazer
Asking price is $6k but I believe I can negotiate down quite a bit. I live in Ontario, Canada.
Old Jun 3, 2008 | 02:28 PM
Sterling's Avatar
Sterling is an unknown quantity at this point
get them down to 4k
blazers live forever if they're taken care of, mine has almost 170,000mi on it and still runs great (granted i had to replace a lot of crap)
Old Jun 3, 2008 | 05:37 PM
fourtwenty's Avatar
So it seems like a decent enough truck. The only thing I noticed was a faint smell of rad coolant when I turned the heater on. What are the chances the heater core is leaking without any visible signs of a leak?
kevlar974
Jul 4, 2011 01:01 PM
joeyf0487
Jan 18, 2011 05:34 PM
Dbam31
Jun 1, 2010 11:15 PM
ericthughes
Mar 16, 2010 09:12 PM
v8 jago
Oct 26, 2008 03:58 PM
