Difference between 97 and 02 blazers
Old Oct 15, 2008 | 06:45 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default Difference between 97 and 02 blazers
So I finally found a new body for my rusted 4x4, the only prob. isthat itis an 02 2wd and I am keeping all the factory 97 stuff. Will the body bolt on to my frame? Will all the electrical connections be the same? Anyone see any problems with what I wanna do?
Old Oct 15, 2008 | 09:06 PM
Default RE: Difference between 97 and 02 blazers
There were some significant changes between the 97 and 98 vehicles in regards to interior and electrical. If you can swap the complete dash, you may be able to get everything to work. But that is a big IF. The body should physically bolt on properly.
Old Oct 16, 2008 | 02:09 PM
blazin97's Avatar
yah I was going to switch the whole int. because the 02 has the ugly brown int. and the 97 has gray...so thats what I am going to do.
What about the doors. I know the handles and locks are dif. how can I make my door panels work??
Old Oct 16, 2008 | 02:10 PM
I do wish you luck. That is going to be a LOT of work!
Old Oct 16, 2008 | 02:12 PM
blazin97's Avatar
I already got most of the 97 apart trying to fix all the rust that went threw, but now I dont have to worry bout that.
I am getting it monday so by sunday it should be done.
Old Oct 16, 2008 | 06:16 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
why don't you just cut where the rust is then cut the same piece off of the other body? IMO it wwould be alost easier than taking everything out, taking body off,putting new body on, putting everything back in, making sure everything works, and so so. yea you might have to repaint the body but it might just be work it.
Old Oct 16, 2008 | 10:32 PM
blazin97's Avatar
IMOthis is easier.
I also changed my mind, I amgoing to use the 972wd frame for the 02 with all the 02 stuff inside and rear end with discs(yahhh). The only thing im using from the 97 is the frame, motor, and exhaust.
Old Oct 16, 2008 | 10:37 PM
djdrew010's Avatar
wouldn't you lose your 4wd then?
Old Oct 17, 2008 | 06:44 AM
Be careful. The 02 electronics are quite different. Your 97 will have one more O2 sensor and the 02 will not have an EGR valve. The 02 will also have different wiring for the knock sensor. The 02 4.3L has different machining for the knock sensor as well.
Old Oct 17, 2008 | 06:36 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
He is keeping the truck that is 4wd. He has another blazer in the garage that is 2wd. That is the frame that he is using.
We got the body completely off the 97 today. The 02 is being delivered on Monday, so that will give us a couple of days to clean the frame up. Attached are a couple of pictures of the 97 frame and the body.
We will definitely have to look into the wiring.
Thanks for the help so far.
[IMG]local://upfiles/7885/F114FDC27F4544048C32EEF6F9C6540D.jpg[/IMG]
[IMG]local://upfiles/7885/FFE998304C5F4F848B8677F369B774A9.jpg[/IMG]
fbkronos73
Dec 28, 2009 02:25 PM
Asimm
Feb 17, 2008 11:29 AM
bitbandit
Tires and Wheels
Feb 12, 2008 02:41 PM
nofear17bmx
Aug 3, 2007 11:24 PM
Pugsley
Feb 2, 2006 10:08 AM
