DIY thread possibility
Old Mar 25, 2008 | 03:25 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default DIY thread possibility
Well, I just did a quickie fix, heater core flush to get my heat working. I know it won't last long, but it will work until I can flush my entire cooling system. I snapped a few pics and was wondering if any of you would find it helpful if I made a DIY thread for getting your heat to work without having to immediately flush the entire system? I mean I will clearly state that it is a temporary fix and a full system flush is needed. Just thought it might be helpful, but I wont waste my time if it is not going to be useful to anyone.
Old Mar 25, 2008 | 04:24 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
Default RE: DIY thread possibility
i think that any well written how to would be useful to someone someday.
Old Mar 25, 2008 | 04:26 PM
WolfPack's Avatar
If you do it, I would be sure and explain when a heater core flush would be beneficial as opposed to the whole system flush. I can't say I really know...
And are you talking about just unhooking the two hoses at the firewall that go to the core, or are you talking about removing the dash panels and getting at it that way..?
Old Mar 25, 2008 | 04:33 PM
a_tack's Avatar
im making it now.. it will be in gen. tech help and probably moved to DIY sec..
Old Mar 25, 2008 | 07:16 PM
Sounds good! Make the thread in the appropriate Tech section (2nd gen in this case) and I will copy it to the DIY section, leaving the original for the discussion thread.
Old Mar 25, 2008 | 07:48 PM
a_tack's Avatar
whoops kyle... i left it in gen tech help... forgot about the subsections!! move it plz?
Old Mar 25, 2008 | 08:44 PM
Will do, no worries!!
matt92
Jul 28, 2011 09:39 AM
cameronp29
Tires and Wheels
May 27, 2009 04:07 PM
WolfPack
Mar 28, 2008 09:40 PM
