Does It have 3.08 Rear End Gear??
Old Sep 22, 2008 | 09:15 AM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
Default Does It have 3.08 Rear End Gear??
I would imagine that most everything that applies to an S10 Blazer also applies to a GMC Jimmy.
I would like to know which rear end gear my 99" Jimmy has.
At 65 mph the tach says 2500 rpm in OD lock up. I'm guessing GM offers 3.08 and 3.73 rear end gears. I hope mine is a 3.08.
Is there something in the VIN denoting rear gear or a tag somewhere indicating the gear ratio?
I need schoolin on these veHickles. Any other info would be appreciated.
And I thank You
Old Sep 22, 2008 | 09:21 AM
Default RE: Does It have 3.08 Rear End Gear??
Search FTW!
RPO code list in your glovebox will have the gear ratios:
GT4 - Axle Rear 3.73 Ratio (Dup with 5X1)
GT5 - Axle Rear 4.10 Ratio (Dup with GT8)
GU4 - Axle Rear 3.08 Ratio
GU6 - Axle Rear 3.42 Ratio
G67 - Level Control Auto, Air
G80 - Axle Positraction Limited, Slip
99Legendary
Jun 30, 2015 08:48 AM
shotnva777
Nov 9, 2011 06:40 AM
brino1
Feb 25, 2011 08:05 PM
redpeppers
Apr 7, 2007 04:55 AM
