Door hanging low
Old Oct 7, 2014 | 10:15 PM
Rww's Avatar
Rww
Rww is on a distinguished road
Default Door hanging low
On my 2001 blazer my driver side door is hanging low and was wondering where I can order new pins to hold the door in place. Thank you.
Old Oct 7, 2014 | 10:30 PM
odat's Avatar
most part stores carry the bushing pin kit - I bought my last one at orileys
Old Oct 7, 2014 | 10:35 PM
cleburne red's Avatar
X2 for O'reillys. That's where I bought my pin kit. Although, if the holes are to worn out, the door might still sag.
Still can't figure out why GM decided it was a good idea to weld on the hinges...
Old Oct 8, 2014 | 08:44 AM
Knightsmove6's Avatar
Knightsmove6 is on a distinguished road
Try rockautoparts.com
Old Oct 8, 2014 | 12:50 PM
Leaky 4.3's Avatar
Leaky 4.3 is on a distinguished road
Like was mentioned, most parts houses have the rebuild kit of the pin and the bushings.
I had a door where the pin had eaten through the bushing and into the hinge itself.
Luckily, the new bushing still fit without rattling around, there was just a section of the hinge that normally traps the bushing that was missing now. Once I had it all installed but still had the weight of the door held up by a floor jack, I used some of that 2 part steel epoxy that comes as a stick where you cut off what you need and just knead it together to make it cure. Then it was just a matter of packing it into the void so the bushing once again had support in that area and didn't get torn up again too easily.
coorsoman
Mar 31, 2011 04:18 PM
goldrushusmc
Aug 8, 2009 11:48 PM
zippy199
Aug 2, 2009 01:58 PM
Canadian88
Jul 20, 2006 08:41 PM
dude5l
Jul 19, 2006 01:00 AM
