Door Hinge Replacement
How would i - without special tools - go about replacing the hinges entirely on a 4Dr for the front doors, the sprigns are already missing, and would kits from a C15/2500 Suburban/Truck Work?
There are plenty of videos on youtube that show you how to replace them. That's how I learned that I could do it. I bought a set of four pins on amazon for about $13 (driver and passenger doors). I would just buy the door spring compressor tool on amazon too. I paid about $7 for mine a lot easier than trying to borrow one at the auto parts store.
The door spring can also be found on amazon for about $3. Junk yard blazers and S10's have them too. But again you need the door spring compressor tool.
If your door spring is gone I would take a look at the roller pin. It looks solid but if you put a screwdriver and gently move it and you feel some give that means it's probably cracked and will need to be replaced otherwise you will lose the new spring you put in. The door roller pin replacement part is a going to be a lot harder to locate. Some people mentioned pulling one off the door from the junkyard.
I am going to be replacing mine this coming weekend and I will update my thread on here so you or anyone can see how it goes.
2000 ZR2 Refresh
2000 ZR2 Refresh
I replaced the bushings about 10 years ago (maybe I should look at them again!). I had a friend help with holding the door up I think. If I were to do it now, I'd do it in my garage and support ithe door with ropes to the roof frames and with a 5 gallon bucket underneath.
What really helps the the spring removal/installation tool.
![](https://cdn11.bigcommerce.com/s-sno9i5h1rz/images/stencil/1280x1280/products/416/3684/doorspringtool-1-__94618.1574500354.jpg?c=2?imbypass=on)
I wish there were hinges available that using some sort of roller bearing instead of the bushing inserts. Would probably last a LOT longer...
I've though about modding the original hinges, finding some small roller bearings that would work and drilling the holes out to fit them.
It's aggravating that they're welded to the body and door. Why GM couldn't just fasten them on with a few bolts is beyond me...
bit of a dead thread but this is still something i would like to know - How are the hinges welded on to these trucks? Door and body side, Seam welded around the edges or spot welded, and is it possible to remove them at home.
I believe they're just plug welded to the body and the door. I'm not 100% sure, but I don't think there's a weld bead around the outside edges of the hinge where it meets the sheet metal on the body and door.
