Door pins -.-
Old Apr 19, 2018 | 05:03 PM
David Filosa's Avatar
David Filosa is on a distinguished road
Default Door pins -.-
so I just replaced my door pins about 2 months ago and same before then... getting tired of these pins, does anyone have any ideas that will fix this? Even like a hinge swap that would work. I have a welder. And grinder. Or any tips other than these brass bushings and pins. Let me
know
Old Apr 19, 2018 | 10:37 PM
N. Jensen's Avatar
My buddy is having the same issues with his '98 s10 pickup. I noticed he is also missing the spring that sits near the bottom of pin... Not sure if they are related.
Old Apr 20, 2018 | 04:45 AM
GreenBlazer2002's Avatar
The spring provides tension for the hinge detent. It helps prevent the door from simply flying wide open when you open it.
Old Apr 20, 2018 | 10:55 AM
I'm doing mine soon, I cant remember who wrote it, but they were able to find some greasable door pins. and I remember another one saying he used washers and that prolonged the life a little. I have not tried either one of these methods, but I myself changing my door pins for the fourth time in 2 years. so ill be doing one of the two options.
Old Apr 21, 2018 | 08:06 AM
newguy's Avatar
I`ve read people using grade 8 bolts
Old Apr 25, 2018 | 02:48 AM
I had the pins replaced 3 years ago when I fixed my drivers side door.
Bronze bushings and pins, properly set and added a reasonable amount of grease.
No problems since.
Old Apr 25, 2018 | 02:09 PM
canadianbacon's Avatar
canadianbacon is on a distinguished road
I used the Dorman pin kit on my bottom pin on the drivers door, been there for a couple months and it's still fine. Are you guys sure nothing is bent in your hinge assemblies?
kiwi
Nov 6, 2009 02:43 PM
kross
May 16, 2008 08:54 PM
BlazEnvoy
Feb 14, 2008 05:01 PM
tammikm
Dec 3, 2007 02:26 PM
Xtreme Blizz
Aug 11, 2007 10:50 AM
