Evap leak test. P0442
Old Oct 10, 2025 | 12:00 PM
Clab's Avatar
Clab is on a distinguished road
Default Evap leak test. P0442
Did a evap smoke test. Closed the vent valve. Smoke seemed to be pouring out of the fuel cap. Figured that was my problem for my p0442 code. Pretty new ac delco cap like a few months old. Figured that was my issue when I went to purchase a new one I seen it said vented. Are the gas caps vented? Or is there a brand you guys would recommend?
Old Oct 13, 2025 | 03:03 PM
1973novass307's Avatar
1973novass307 is on a distinguished road
Default Evap
I went down the evap rabbit hole, ended up being filler tube to tank was rusted. Also replaced vacuum line that runs over left rear tire on top of frame to engine. I recommend genuine gm cap. It solved my problem.
Old Oct 14, 2025 | 12:51 AM
Clab's Avatar
I seen a very small amount of smoke from the rubber hoses connecting filler neck to tank so pulled it and replaced those and the gas cap was my main leak. Went to turn the key and had fuel spraying from the supply line and return all of it is super rusted right there so now replacing fuel lines. Probably bumped them when taking the filler neck out.
Old Oct 14, 2025 | 08:18 AM
GeorgeLG's Avatar
What are you using for smoke testing?
George
Old Oct 14, 2025 | 09:36 AM
Clab's Avatar
Autoline pro Smoke machine I got off Amazon. Worked better than I expected for the price.
Old Oct 15, 2025 | 02:28 PM
Default Fuel leak
They sell a poly line kit for fuel line replacement, cheap easy and fast. Used it when I replaced the tank. It sprung a fuel leak when I replaced break line to back axel.
Old Oct 15, 2025 | 05:04 PM
Clab's Avatar
waiting on the nylon kit to come in the mail right now should be here soon! Then I get to test drive make sure the p0442 goes away. Thanks fellas appreciate the help!
KevinZ
14
Jul 6, 2025 03:46 PM
jasondis
206
Oct 28, 2024 01:00 PM
Doubledown
Jul 17, 2019 05:21 PM
