Filling The Rear Diff
The first picture shows the fill plug on the passenger`s side of the housing.
You may need a longer tube to be able to refill the diff. Either that or buy 3 quarts and just tilt each one up as far as you can because you will not be able to tilt them all the way. You will have a little left over in the first two, just pour it into the third and fill until the fluid level is just below the fill hole (test it with a finger).
Drain plug - my 3/8" to 1/2" adapter fit perfectly into the square.
cdngreenmachine
Aug 8, 2011 03:48 PM
