firewall question
Old Jul 16, 2010 | 03:54 PM
carlosg7915's Avatar
carlosg7915 is on a distinguished road
Default firewall question
Im trying to run a battery wire thru the firewall. anybody know where the hole is to run the wire?
Old Jul 16, 2010 | 10:42 PM
DKSDAD's Avatar
You will probably have to make your own or if it will fit check to see if you can pass it through the opening for the steering column.
Old Jul 17, 2010 | 10:21 AM
chiefum's Avatar
chiefum is on a distinguished road
If you make a hole......I would use a rubber grommet.
Old Jul 17, 2010 | 11:27 AM
i guess i'l make one then. any suggestions where to make it? last thing i want is to break something
Old Jul 17, 2010 | 12:56 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Personally I did away with factory antenna and replaced with an interior mounted amplified antenna (can't see it unless you know where it is and what to look for and the reception is WAY better than the factory exterior one) and used the factory antenna hole/grommet for mine, just a suggestion.
Old Jul 19, 2010 | 11:14 AM
found it... its right under the rug on the passanger side, if anyone ask's.
carterx
Nov 30, 2009 01:39 AM
madeforliving
Feb 16, 2008 12:59 AM
djkrash
Jan 8, 2008 03:23 PM
EuroGoldLS
Jun 15, 2007 04:11 AM
Kaffeene
Apr 25, 2007 10:03 PM
