Free DIY ABS EBCM Fix
Old Feb 5, 2013 | 10:21 PM
Michaelwiseguy's Avatar
Michaelwiseguy is on a distinguished road
Default Free DIY ABS EBCM Fix
Not sure where to post this for lurkers looking to fix their Electronic Brake Control Module and idiot lights?
Today I fixed the ABS EBCM on my 2001 2dr 4wd. Idiot brake and ABS have been on for the past 3 years. I heard it could cost $1,200 at dealer to fix. I never take my vehicles to the dealer to have fixed. Did a little research on the C0265 code and found the $0 fix. I took out the EBCM and worked on it at the kitchen table for about an hour. I used a couple of thin metal spackling knives and a strait blade to cut through the top cover silicone seal. After I got the easy corner up I just worked around the spackling knives and cut the silicone with the razor blade. 6 small torx screws held my cover on and I just resealed it with the screws so it will be easy for me to get off again if I need to. Here's the Youtube video on how to fix it for free and it worked for me.
*REAL* FIX ASTRO-VAN KH325 EBCM (brake & abs light on intermittently; C0265 code
Old Feb 8, 2013 | 10:12 PM
AJBert's Avatar
As informational as this video may have been I just couldn't watch more than about 30 seconds due to the music and narration.
No offense meant to the OP. Just not my idea of an informative video.
Old Feb 8, 2013 | 10:38 PM
*Yawn* yeah, no kidding! However, if that's the problem it's a cheap fix.
Old Sep 1, 2013 | 06:23 PM
ddarther's Avatar
ddarther is on a distinguished road
Smile fix works
I was having this problem with my blazer and tried this fix took me less then 20 min and so of the was waiting for the soldering iron to heat up. But it fixed it and have not had any trouble sense. So though the video could be a lot better thanks for the quick and easy fix
Old Mar 8, 2022 | 12:40 PM
Mr. Shannon's Avatar
Mr. Shannon is on a distinguished road
Default Fixed ecbm with solder, found a few cracked points
So here's the deal. The light would come on when it's dry out, go out when raining. I took to a shop, they wanted 1100.00 to fix. Yikes! I found the 0$ fix, did it, put it back in and the light is out. I press the brake pedal to put it in drive to test it and the pedal goes to the floor. Pumped and pumped, nothing! I only removed the ecbm, never messed with the brake lines. What's going on? I even unplugged the battery for 24 hours and reconnected, same thing!
gturb03
Mar 4, 2012 07:17 PM
Kaffeene
Feb 29, 2012 07:29 PM
Kai
May 8, 2011 08:01 PM
warthogdriver
Nov 7, 2009 07:40 PM
Slnt Dnky
Jan 19, 2009 01:58 PM
