Gear ratio question
Old May 4, 2009 | 09:07 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
Default Gear ratio question
Hope this isn't such a stupid question. How does one tell what gear ratio is in his/her Blazer?
Old May 4, 2009 | 09:18 PM
bandidolenny's Avatar
Jack up the rear end and put it in neutral. Mark the driveshaft with something like liquid paper. Get a friend to help and each of you simultaneously spin a rear tire forward one complete turn. Note how many times the driveshaft turns. If it turns just over three times that would be a 3:08 ratio. Just under three and a half turns would be a 3:42. three and three quarters would be a 3:73 etc...
Old May 4, 2009 | 09:57 PM
TripleBlackBlazer's Avatar
Or check your RPO codes in your glove box (2nd Gen) or elsewhere. Not sure where they are on a 1st Gen.
GU6 is 3.42's
A quick search of "gear ratio" or "RPO codes" should yield the rest of the codes.
Old May 4, 2009 | 10:30 PM
TomSawyer's Avatar
Thanks for the info and quick replies. Bandidolenny, it never occurred to me what you suggested, it's a manual / physical way of finding the answer, it makes absolute since. I was thinking more along the lines of what Tripleblackblazer mentioned, some numbers somewhere or a stamp on the axle, or at least something along those lines. Either way, great input, thanks!!! If I ever work on a really old vehicle I'll have two options now to figure out this question. Thanks again!
Old May 6, 2009 | 04:15 PM
You are welcome. Also, the next time you are changing the diff fluid and have the cover off, look for numbers stamped into the edge of the ring gear. You will see something like 41:12 . The first digit is the number of teeth on the ring gear, the second digit is the number of teeth on the pinion gear. If you divide 41 by 12 you get 3.41667 or what we call a 3:42 gear ratio. Just another way to do it...
Old May 8, 2009 | 09:43 PM
TomSawyer's Avatar
Cool! Thanks for the additional info, it's nice to know.
Old May 10, 2009 | 12:40 PM
oisinirish's Avatar
Thumbs up
This should almost become a DIY or FYI reference! Nice!
shotnva777
33
May 22, 2012 10:52 AM
dagda
Jan 12, 2010 06:37 PM
odfareal
Sep 25, 2009 12:07 AM
Outsydr
Feb 26, 2009 10:45 PM
ceanern
Jun 17, 2006 08:44 PM
