hating GM right now
Old Nov 10, 2007 | 12:18 PM
  #21
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: hating GM right now
My guess is that either you have a bad 4x4 switch or the vaccum switch on the transfer case if boogered up/needs replacement. I am not sure on what the costs of these are but I am guessing that the 4x4 switch should be about $30. If the vaccum switch is bad then it would be pretty difficult to get it back into 2wd (takes multiple tries to get it in). Hope this helps you out some.
Old Nov 10, 2007 | 12:20 PM
  #22
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Yes that's is whats is doing
Old Nov 10, 2007 | 12:21 PM
  #23
I went to Autozone.com and found the part on their web site they want $53.00 + tax on it. May check a junk yard or something
Old Nov 10, 2007 | 01:40 PM
  #24
Blaze GM4's Avatar
Blaze GM4 is an unknown quantity at this point
It sucks to have to unload a bunch of cash on your vehicles at one time but you should realize that this could happen to you ifit's a Ford, Dodge or (God forbid) Import.
But once these repairs are done they'll be out of your hair for a while.
I've got the last year of the fullsize blazerwhich happens to have a diesel. I picked it up last year for 14G with 220,000km. So far i've replaced the alternator twice and recently the engine has been running rough with no codes to go by so i have to replace parts one by one untill it's fixed. Being electronically injected the obvious would be the Fuel Solinoid Driver $400, then the Injection pump $1100 and the injector nossles (should be replaced with the pump) and a set of performance marine nossles go for $500.
These prices are for parts alone and if i wanted Genuine GMjustmultiply by 2. There's over sixteen hours involved inshop labourso luckily i'm mechanically inclined
Given the rarety of these trucks I have no problem with repair costs, it sucks but i think it's worth while since this truck is practically showroom quality.
The only thing with trading in for a different truck, better the devil you know than the devil you don't
Old Nov 10, 2007 | 02:47 PM
  #25
Psychropod's Avatar
Psychropod is an unknown quantity at this point
ORIGINAL: cjh
I feel your pain...just bought a 96, havent had it on the road yet cause the frickin' brake lights don't work.
I cant figure out how to get at the turn signal switch. I'm thinking of removing it with a 9 iron.
This should probably be posted in another thread, but I have to reply, since I also have a '96 and have done this.
You have to remove the bottom panel of the dash. If you look under the dashboard, there is a line of screws running along the bottom edge. Just remove all of these, and the panel lifts up enough for you to get to the turn signal switch. There may be a couple more screws near the radio that you might have to remove. The switch is located right next to the cigarette lighter and ashtray. It's a pain in the butt, but it's not too hard. Also, since the turn signal and hazard switches are right next to each other, you may as well replace both, since the other one may have never been replaced anyway.
You can do it in about an hour. Good luck.
Old Nov 11, 2007 | 09:56 AM
  #26
blazinloud's Avatar
Replaced my TCCM, part was $250, labour was $150. 4x4 works fine.
although im yet to try 4lo, we just got a bit of snow and I have to travel almost 300km tomorrow, so itll get a workout anyway......4hi that is
Sisk
May 2, 2011 05:02 PM
bmx4life218
Aug 3, 2010 01:32 AM
HcHawks09
Apr 23, 2010 08:28 PM
kikkegek
Tires and Wheels
20
Oct 12, 2009 08:04 AM
redpeppers
Apr 7, 2007 04:55 AM
