hood latch problem
Old Nov 22, 2008 | 07:13 PM
ryansoxfan's Avatar
ryansoxfan is an unknown quantity at this point
Default hood latch problem
my 02 blazer's hood won't open. i try pulling on the cable and it still won't pop open. does anyone have a diagram showing the latch mechanism?? any other ideas?? thanks.
Old Nov 22, 2008 | 10:25 PM
vin791's Avatar
vin791 is an unknown quantity at this point
Default RE: hood latch problem
im guessing either the little thing that grabs onto the cable that pulls your opening mechanism came loose or you just need to pull up on your hood a little, then open it then it should work. sometimes these latches are a little screwy.
Old Nov 22, 2008 | 10:37 PM
WolfPack's Avatar
Mine used to do that, but a few liberal treatments with WD-40 and dry silicone got the system working flawlessly. But, you could have a problem with your latch I suppose.
When mine was stuck, I had to push down on the hood front and center then pop it up by hand, or, a hard whack by the rear hinges sometimes gets it loose. Worth a shot
boscoedoodle
Oct 7, 2009 06:58 AM
03RedBLazerXtreme
Sep 23, 2007 03:31 PM
blazer4x4
Sep 12, 2007 11:59 AM
JST4SHO
Apr 29, 2007 04:33 PM
Blazenfast
Oct 15, 2006 09:53 PM
