Hooking up a CB Radio
Old May 11, 2010 | 05:20 PM
20004wdblazer's Avatar
20004wdblazer is on a distinguished road
Default Hooking up a CB Radio
I am interested in hooking up a CB radio in my 2000 Blazer. I have all the tools/supplies to put in the radio, but I don't know how to hook it up to the battery for power. I don't want to use a cigarette lighter adapter, so how would I go about hardwiring it into my Blazer? Thanks a lot.
Old May 11, 2010 | 05:54 PM
sifd4x4's Avatar
sifd4x4 is on a distinguished road
You can either tap into an open spot in the fuse block or run a power wire in off the battery. Either way you will need to make sure to use an in-line fuse thats big enough and use heavy enough gauge wire. If you use the fuse panel then you can make it where the cb will only be on when the ignition is on or if its directly to the battery it will have constant power.
Old Jun 4, 2010 | 10:01 AM
nit8690's Avatar
nit8690 is on a distinguished road
I have wondered this to. how hard is it to tap into the fuse block?
Old Jun 4, 2010 | 12:43 PM
jmaynard's Avatar
jmaynard is on a distinguished road
Don't bother with the fuse block. Go straight to the battery with at least 16-gauge wire (assuming you're running a legal CB). That's the best way to keep any crap in your car's electrical system out of your CB, and vice versa.
I've always wired my ham radios to the battery, and it's worked well every time.
Spectreblazer
Mar 9, 2010 07:43 PM
6700
Feb 9, 2010 07:54 PM
Crestwood1001
May 26, 2009 08:16 PM
spankyy
Mar 27, 2009 09:02 PM
ftwflh
Dec 27, 2008 05:43 AM
