How Can I Tell A ZR2 From A FAKE ZR2?
How can i tell a ZR2 from a fake ZR2? I am in the market. How do the skid plates on the ZR2 compare to the Non ZR2. I looked ata ZR2 the other day with 3 skid plates, the one up front was plastic, I dont know what the other two were. What are some tell tale signs that tell me the difference between a ZR2 and a non ZR@ with fender flares bolted on?
Check the RPO codes in the glovebox for "ZR2". Also, I believe they all got the 8.5" rear ends which are more round in shape whereas the 7.5 and 7.625 rears are more oblong/oval shaped.
Wiki has some good stuff HERE, and some other valuable information can be found HERE.
x2 on all that stuff.
They had aluminum skid plates to answer your question. The front one I believe is always plastic as it is just a splash guard, not a skid plate.
But all those parts can be bought and added to inflate the value. Only true way is to check the RPO codes like TBB said.
ORIGINAL: WolfPack
If you needed to order any of these parts, they are listed as skidplates, not splash guards.
Fair enough! Thanks for the correction verno
So if the OP found that supposed ZR2 with 3 skid plates, but the front being plastic...it's a fake ZR2? Orrr do the composite plates feel plasticy?
ORIGINAL: myol blue4x4
Another give away would be the frame, on a non zr2 you would see the big ol' frame underneith and on the zr2 it has the ladder frame.
ORIGINAL: Verno
This one I've never heard of, care to elaborate.
sasquatchfound
May 30, 2007 08:46 AM
john50
Apr 13, 2006 01:45 PM
ivannj
Dec 21, 2005 11:02 PM
neogeo92
Oct 8, 2005 03:19 AM
