Intermittent Electrical
Old Oct 28, 2024 | 11:36 AM
Bruno1ud's Avatar
Bruno1ud is on a distinguished road
Default Intermittent Electrical
I have an 1986 K5 with 6.2 diesel with an intermittent problem. Usually starts right up no problem but sometimes when I turn the key all gauges are dead and will not crank. If I keep cycling the key and mess with the door locks all the sudden everything lights up and it fires right up again. Is there a module or relay that I need to look for or is it a bad ignition switch. Are there any loose connections that I should be looking for. Thanks for your help.
Old Oct 28, 2024 | 12:13 PM
GeorgeLG's Avatar
One approach would be to probe the output wires from the ignition switch to se what you get when in run or start and the truck is misbehaving and go from there. I think I have some K5 wiring diagrams somewhere if you want to go that route
George
Old Oct 28, 2024 | 12:20 PM
Bruno1ud's Avatar
Thanks GeorgeLG I am going to check the ignition switch. If that does not work I will need the diagrams
Old Oct 28, 2024 | 01:05 PM
GeorgeLG's Avatar
The trick is to see if 12v shows up on every output wire when it should in run and/or start. I think that this is a good diagram for the ignition switch on your truck:
George
Nick_200321
Nov 12, 2020 10:20 AM
d w schaefer
Apr 12, 2019 05:51 AM
greasyhands
Dec 18, 2012 06:42 PM
Aaron121782
May 30, 2012 08:07 PM
kalel35
Dec 27, 2009 12:34 PM
