Leaking brake fluid from banjo bolt.
Old Sep 4, 2019 | 01:59 PM
Kevin Piner's Avatar
Kevin Piner is on a distinguished road
Default Leaking brake fluid from banjo bolt.
I just replaced my front brakes on my 98 blazer. On the drivers side only the banjo bolt is still leaking after putting the caliper back on. Any ideas why it's still leaking.
Old Sep 4, 2019 | 02:17 PM
You mean the bolt holding the hose to the caliper?
Did you make sure to put the copper washers on? Maybe didnt tighten it enough?
Old Sep 4, 2019 | 04:10 PM
I got I fixed needed New banjo washers...
Old Sep 4, 2019 | 05:25 PM
Glad its fixed
Old Sep 5, 2019 | 02:43 PM
jimspahr@msn.com's Avatar
I had a similar leak with my rear brake caliper replacement and it turned out to be -----the banjo washers. I used the ones supplied with the new caliper and they were steel. Leaked . i tried some copper aftermarket ones--Dorman --- and they leaked. I went back to the original ones and they leaked. Very frustrating.
phxjosh
Mar 8, 2018 12:46 AM
Joey1986Z
Jan 23, 2014 02:59 PM
lombard
Mar 28, 2011 06:23 PM
GregC5
Mar 22, 2009 08:48 PM
davtak
Sep 23, 2007 10:14 AM
