Lift Gate Will Not Open
Greetings All...
I recently acquired a 1997 Chevrolet Blazer and now, the rear liftgate will not open from the dash switch nor by the rear handle, is there a manual door lock on the rear liftgate that I can release of how do I get the gate to manually release ?
Thanks,
Thanks,
Sounds like your lift gate motor went out. That's about $60-$70 to replace. Mine went out in my 2001 Xtreme blazer. In the panel there is a small rectangular hole in the center top behind the carpet that you cannot see (at least minie was). There is an emergency latch inside there but you have to use something small like a really stiff coat hanger or screwdriver. Move it side to side until you hear a click. When you hear a click your lift gate will open up then you can drop your tail gate, take off the panel and un-screw the metal panel careful not to damage the rods behind it. The motor should look like a square box.
Does your manual that came with your blazer not tell you? Mine did, took me forever to figure the emergency open latch.
Gailstrail
Oct 3, 2010 06:51 PM
ensembledwar
Mar 7, 2010 12:13 PM
web road runner
Nov 13, 2007 10:15 AM
