NEED HELP NOW!!!
Old Mar 2, 2008 | 12:27 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default NEED HELP NOW!!!
Okay... my utility trailer has officially pissed me off...... I am having horrible problems with my trailer lights.... I have been through 2 wiring harnesses and 2 sets of taillights and both are doing the same thing.. well sort of....
1st set:
Headlights off:
turn signals work
brake lights work
Headlights on:
taillights work
turn signals work
brake lights dont work....
when I hit the brakes the whole taillight just turn off.....
2nd set:
Headlights off:
turn signals work
brake lights work
Headlights on:
taillights work
turn signals work
The same thing happens hooked to my blazer and my silverado.... my silverado is factory wired for a trailer... so it cant be the trucks right?? oh yeah... the second set of lights/wiring harness does nothing when hooked to my blazer.... it works as listed above when hooked to my pickup...... this is very very maddening.....
it is a 4-flat wiring harness and not only did I scrape the powdercoat off of the trailer for the ground, I used a self-tapping sheet metal screw......
PLEASE SOMEONE HELP ME!!!!!!!!!!!!!
Old Mar 2, 2008 | 12:43 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: NEED HELP NOW!!!
wow almost sounds like the wires on the trailer r messed up and maybe switched around
Old Mar 2, 2008 | 12:44 PM
Chevy Lover's Avatar
Does this help?
[IMG]local://upfiles/2910/37B8488688B64956BE41FF72A41C5192.jpg[/IMG]
Old Mar 2, 2008 | 12:55 PM
a_tack's Avatar
I've wired so many trailers its not even funny..lol thats why this makes me so mad.... I mean the wires are color coded... pretty hard to mess up......
the wires are all correct... the lights that work also light up dimly......... maybe the lights arent getting a good ground where they mount to the trailer????
i know that
brown-taillights
green-right turn/brake
yellow-left turn/brake
white-ground to trailer
if the wires weren't right then they wouldnt work at all..... this only happens hooked to my blazer... hooked to my pickup they all work correctly unless the headlights are turned on...
it isnt the trucks because I just hooked my boat trailer to both of them and those lights work properly..
the lights mount to L-brackets that bolt to the trailer frame, however, the bolt holes and trailer frame are powdercoated... could this cause the problem??? I mean, the lights technically ground to the frame through the bolts they mount with right?
Old Mar 2, 2008 | 12:59 PM
Blazin_Jason's Avatar
Take a meter and test all the connections. Make sure that the wires don't have continuity to ground that shouldn't. Test voltage at the lights. Disconnect one light and test it all out, then test the other.
Old Mar 2, 2008 | 01:20 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Yeah I think the lights do ground thru the bolts that they mount with, so try scraping some powdercoat off where the bolts mount up and then try it again. I know crappy/loose grounds can cause lights not to work.
Old Mar 2, 2008 | 01:42 PM
a_tack's Avatar
FIXED IT!!! could not ge ta good ground anywhere except the trailer tounge... sooooo I ran a ground wire from the light mounting bolts through the frame rail and to a self tapping screw on the tounge.... works perfect now.. thanks for all the help guys!
Old Mar 2, 2008 | 02:04 PM
good to hear u figured it out!
Old Mar 2, 2008 | 03:32 PM
Glad thats solved for you. Its weird that you could only get a good ground at the tounge.
AreaCode215
Nov 7, 2011 03:07 PM
bmx4life218
Aug 3, 2010 01:32 AM
Ridinblazer
Nov 8, 2008 04:52 PM
TheDesertFox
Oct 10, 2006 05:32 PM
