No Fluid
Old Aug 9, 2010 | 09:15 AM
01BlackBeauty's Avatar
01BlackBeauty is on a distinguished road
If the plunger is in the depressed position then the proportioning valve should center itself once fluid pressure is applied to it. Did you prime (bleed) the master cylinder prior to trying to bleed the brake lines?
Old Aug 9, 2010 | 10:53 AM
sgp7679's Avatar
sgp7679 is on a distinguished road
the master cylinder was never run dry with fluid, so no i didnt bleed the mc. Im thinking I may have to much air in my line and Im going to try gravity bleeding the rear.
*EDIT 1*
well been gravity bleeding right rear for an hour now and nothing is coming out
*EDIT 2*
ok finally got it, whoever owned it last plugged the line coming from the master cylinder to the rear brakes with a screw because of the busted cylinder. glad it was just a screw. Brakes are working good now.
Old Aug 10, 2010 | 01:20 AM
old skool luvr's Avatar
WTF is wrong with some people?!!!
Old Aug 13, 2010 | 01:52 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
what did this screw plug look like?
Old Aug 13, 2010 | 09:25 AM
sgp7679's Avatar
just a regular old screw
Old Aug 13, 2010 | 11:00 AM
I dont understand how a regulaer screw would seal it? there is an inverted flare inside there and the screw would have to have to proper seat to seal properly.... and where was this screw put exactly? im only asking because i may have to do it to my truck temporaly so i can drive it to the shop to get a flare done on the rear line by the shop. please help me and let me know
thanks
Old Aug 13, 2010 | 04:38 PM
sgp7679's Avatar
take the first line that goes to the rear brakes on the master cylinder of and get a round head screw that fits perfectly into the line and stick the screw in the line and hook it back up to the master cylinder and it stops the fluid.
BrinkDiamond
Mar 2, 2014 03:50 PM
Mjseyler
Jan 5, 2010 12:44 PM
DaleA
Jan 13, 2009 08:50 PM
fruccoman
Feb 15, 2006 07:08 PM
Derbytown
Aug 23, 2005 12:00 PM
