No heat after changing out heater core
Old Oct 1, 2023 | 07:45 PM
Alaskantrailblazer's Avatar
Alaskantrailblazer is on a distinguished road
Default No heat after changing out heater core
I replaced my heater core and took my time with it. Now that everything is back together I have no heat. I changed out the blend door actuator and tried to initiate it several upon several times. Replaced a few rotted out vacuum lines. Even replaced the heater hose under the hood which get fire hot I might add. I’ve had the dash out twice and went over everything I can think of to only be defeated. If there is anything anyone could recommend. I’d truly truly appreciate it.
also I might add after every initiation the AC light is illuminated in hvac controls.
Old Oct 2, 2023 | 01:48 PM
Update….I forgot to plug in the sensor in the air duct above the radio.
Old Oct 2, 2023 | 08:37 PM
So does it now work?
Old Oct 2, 2023 | 08:51 PM
Heat only works when it’s turned all the way to the right and it’ll roast you out
72Shadetree
Jun 15, 2022 04:13 PM
Jenna420
Apr 27, 2022 06:42 PM
Walleye Hunter
Oct 26, 2021 05:57 PM
Tomar1226
Nov 2, 2011 09:40 AM
nitrogupy
Nov 15, 2010 10:47 AM
