No lights on 4x4 switch
Old Jan 7, 2023 | 01:47 PM
rockp2's Avatar
Now I think I'm following you, you're referring to the fact that the white printed "2WD""4HI""4LO" isn't illuminating...correct?
Old Jan 7, 2023 | 01:50 PM
Ian McCauley's Avatar
Ian McCauley is on a distinguished road
Correct!
Old Jan 7, 2023 | 01:55 PM
I tested the gray wire(H) to the black wire(G) on the blue connector and got 10vdc. I rotated the dimmer switch up and down and the voltage changed from 10vdc down to 6 and back up so I'm assuming this is means the connections are good and should be enough to power the LED in the switch. Hate gremlins.
Old Jan 7, 2023 | 01:57 PM
rockp2's Avatar
Originally Posted by Ian McCauley
Correct!
LOL. I thought you were saying you had a "4WD" light that was in your INSTRUMENT PANEL cluster. That's why myself and another were wondering what the heck you were talking about.
Old Jan 7, 2023 | 02:08 PM
Got ya. My brain was fried yesterday trying to figure out how to explain the issue I'm having that's why I posted the picture.
Old Jan 7, 2023 | 02:14 PM
GeorgeLG's Avatar
Try this. Your being assisted by others already so I won't jump in unless asked:
George
File Type: pdf
Old Jan 7, 2023 | 02:24 PM
rockp2's Avatar
George
Help him out George. You have the '01 data, connector views, ground locations, etc.
EDIT: I'll be in the background in case I see something that might help.
Old Jan 8, 2023 | 01:59 PM
I tried to measure resistance between pins G and H on two of my switches, one old and one new, with my multimeter. Neither gave me a reading let alone continuity so either the meter is bad or the bulbs are indeed burned out. I have to remember the used ones are old enough to legally drink in the US and new out of the box doesn't guaranty anything.
I did re-solder the pins on both used switches I have, the original functions much better and the 4HI indicator lamp works perfectly now. The 4HI indicator on the used one I bought did not work and only occasionally would shift the transfer case but after re-soldering the pins it is working flawlessly. Only issue is the illumination lamps do not work on either of them.
So I bought a new meter and tested pins G and H on the switches this morning. Still nothing so I'm leaning towards the bulbs being bad, even on the new switch if it even has a bulb. The truck is gone on a fishing trip to Oregon for a couple weeks so it will be a while before I can report back any progress.
Below is the switch diagram I'm looking at. I really appreciate everyone helping me try to figure out what is causing this issue.
Old Jan 8, 2023 | 02:09 PM
GeorgeLG's Avatar
So all of the switch functions now work OK and the only thing left is the panel illumination inside the face of the switch/buttons?
George
Old Jan 8, 2023 | 02:12 PM
rockp2's Avatar
I was pretty amazed when I found those hairline cracks originally that led to writing up that fix thread. I used 10x loop to find them and to be honest I wasn't necessarily even looking for them. I was just trying to see what I could see
