the normal
if it is not to much to ask i was wandering what is the normal numbering/position of all the gauges of the blazer. like the bat., oil p.,and temp., what is normal idle and what is normal drive.
thanks
thanks
the norm for my gauges seem to be : battery gauge is usually about half way 14vols i beleive the oil pressure is about half way when driving the drops a lil when im stopped at a red light or something then it will go to about 3/4 of the way up if i punch it, the temp gauge is usually a lil below 210 degrees and i usually idle around 500-600rpm city driving (25-35mph) about 1500-1800rpm and highway driving (70-75mph) is right around 2000-2100rpm
Hah my battery gauge is about 13volts, my temp is always moving, my oil pressure i think something is wrong because its about 20psi at idle and hardly moves when I'm driving which scares me but it does go 10psi per 1k rpm so I guess its ok. My fuel gauge we all wont go there. Normal idle = 600rpm (aftermarket tach hooked up) 3.73 gears = ~2100 rpm @ 70mph
amkonyk
18
May 30, 2009 11:32 PM
blazinloud
Dec 31, 2006 02:03 PM
