oil leaking
Old Jan 11, 2021 | 12:25 PM
TR860's Avatar
TR860 will become famous soon enough
Default oil leaking
yesterday ran some errands and when i stopped i noticed a smell like rubber burning and some smoke coming from underneath. It stopped so i didnt pay much attention to it. This morning i noticed there was oil on the drive way so i looked under and seen oil dripping from the rear of the engine. Without jacking it up and looking does anyone know what could be the cause or what to look for. '98 Blazer....114700 miles on it.
Thanks
Tom
Old Jan 11, 2021 | 02:35 PM
A sudden oil leak could be a failed o-ring for the remote oil filter lines to block adapter. This is at the rear of the block on left (driver's) side.
Old Jan 11, 2021 | 02:40 PM
TR860's Avatar
Is this something to see and fix....and Thanks
now to get the urge to crawl under it LOL
Old Jan 11, 2021 | 02:41 PM
TR860's Avatar
sorry left out easy to see and fix....need another beer 8^)
Old Jan 11, 2021 | 05:40 PM
It is not too hard to see but a bit harder to fix. It is pretty cramped up in there when it comes to getting the part out but it is definitely a backyard mechanic fix.
If it is the o-ring and you need to replace it, a trick I learned is that for the gasket that is also in there, use a bit of vaseline to hold it in place when you reinstall it.
To get the oil hoses off from the adapter, I used a really long extension on my socket wrench to get at it from the front.
Again, if it is what I suggested, you might consider replacing the oil lines too as they tend to start leaking eventually. There are lots of threads on replacing these.
Example of adapter gasket set: https://www.rockauto.com/en/moreinfo...314133&jsn=672
Example of remote oil lines for 4wd Blazer: https://www.rockauto.com/en/moreinfo...314133&jsn=681
Old Jan 11, 2021 | 06:12 PM
TR860's Avatar
i really appreciate your comments. After talking to some folks they say to eliminate the cooler and lines. So i am asking you, do you have any ideas on doing this.
Thanks
Old Jan 11, 2021 | 07:17 PM
Thanks
I don't know about how to eliminate the oil-cooler lines nor if it is very practical. The remote oil cooling is normally part of the oil cooling system and as such is not a bad thing to have, especially if you use your Blazer for any towing. You might start a new thread asking about deleting the remote oil filter is practical, useful and how to do it.
I wish I could be of more help on that.
Old Jan 11, 2021 | 07:26 PM
TR860's Avatar
You were a lot of help and it is appreciated. Now that i know what to look for thanks to you, i will check my options. Thanks again and have a good new year
Old Jan 12, 2021 | 11:03 AM
You are very welcome. I had this part leak on my 92 Blazer, that is what made me think this could be your situation. Be sure to report back what you learn and good luck!
jiggs240
Apr 15, 2011 03:09 PM
zedartwo
Apr 4, 2010 12:16 AM
mainsail2030
Jul 11, 2007 07:09 AM
pinetopfirefighter
Apr 20, 2007 03:39 PM
96Ls4Dr
Nov 20, 2006 01:44 AM
