Oil Lines...
Old Mar 22, 2009 | 11:04 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Oil Lines...
I just changed out the oil lines that run from the adapter (block) to the filter on my step dads '98 olds bravada. Wasn't as bad as my '93 by any means, but still somewhat of PITA. I didn't replace the lines that go from the filter to the radiator so I'm wondering if I have to worry about them blowing out before I get around to replacing 'em. They do look like they are leaking so should I be concerned? I would have done them as well but no one seems to stock the sob's. I have the same situation on my 93 and they seem to be holding up. Thanks
Old Mar 23, 2009 | 07:37 AM
The upper lines do not flex anywhere near as much or as often as the lower lines. I would not be too concerned with them.
Old Mar 23, 2009 | 09:33 AM
fondo's Avatar
Good call, thanks.
Old Mar 31, 2009 | 02:07 PM
If an oil cooler line ruptures at 70 MPH, the oil pump will empty your crankcase in a heartbeat. You can't shut the engine down fast enough to avoid damage. If they're leaking, they're bad. The filter to radiator lines are much easier to replace than the lower lines. Keep in mind, the OEM lines use a single crimp to attach the hose to the fitting, (cheezy set up). Dorman lines use three crimps, they don't leak. The Dorman Part # is 625-100 and usually cost $30.00 or less. 100 times cheaper than a new engine, why take a chance?
cahlersmeyer
23
Nov 10, 2011 09:23 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
todaresqSL2
Nov 10, 2008 01:47 PM
